Old 01-17-2012, 01:05 AM   #1
art leong
Default Compression ratio math?
I've just measured my motor. And would like to see what compression ratio others come up with?
Here are my specs.
Bore 3.480
Stroke 3.976
Flat of piston is .010 out of the bore
Head volume 49 cc
Head gasket thickness .077
Head gasket bore 3.50
Volume of cylinder with piston .355 down the bore is 47 cc
I believe that will give me a dome volume of 8.33 cc's
Head gasket volume is 12.14 cc's
Cylinder volume is 619.7 cc's
Art Leong 2095 SS
Old 01-17-2012, 01:20 AM   #2
art leong
Default Re: Compression ratio math?
Sorry meant to post this in the tech section.
I've used some of the online calculators and I get some quite different answers.
Numbers vary from 11.7 to 1 to 13.0 to 1
Art Leong 2095 SS
Old 01-17-2012, 01:23 AM   #3
NORMAN BARNARD
Liked 2 Times in 2 Posts
Art. My compression ratio program useing your info. Say's it's 13.1:1 normally aspirated at sea level. I also get the same cylinder volume as you do 619.7 cc's.....hope this helps.....norm
NORMAN BARNARD is offline   Reply With Quote
Old 01-17-2012, 02:04 AM   #4
Liked 1,777 Times in 404 Posts
Using the compression ratio calculator on my copy of Larry Meaux's PipeMax software, I get 13:1.
Old 01-17-2012, 08:44 AM   #5
race watcher
Google compression ratio calculator. A nice site comes up with a number of different tools.
race watcher is offline   Reply With Quote
Old 01-17-2012, 10:29 AM   #6
Ed Wright
Ed Wright's Avatar
Art, you should buy Pipemax. Very usefull.
Ed Wright 4156 SS/JA
