Hi I have block ?. NHRA 307 olds stocker non roller engine. Are you using the factory 307 open main web block in stock or is it legal to sleeve a 330 or 350 solid main blocks?
Thanks Bernhard |
Liked 7,730 Times in 1,739 Posts
Yes, you can sleeve a 330/350 block but I've never heard of the 307 blocks being a problem in a Stocker.
Liked 89 Times in 19 Posts
I've seen a 307 pull the center mains out of the block. It may not be common but it can happen. It isn't a pretty picture.
c
Chuck Norton |
Liked 43 Times in 10 Posts
Some 25 years ago, there were about 6 thousand 307 Olds stockers running around. Those motors were beat to death and proved to be quite durable.
Unless you’re using nitrous, nitro, or some other exotic ingredient, I would not be too concerned with the “windowed mains” scare on Olds motors. |
Liked 5 Times in 3 Posts
Mine is 6800 @ finish line. Oops mine is a hyd roller though
What ,s seems to be the max you 307 builders are boring your blocks to play it safe ? Dennis J/SA
Liked 49 Times in 15 Posts
You should contact Don Forester. He uses Dave Smith engines and they have some of the fastest Olds Stocker stuff out there.
Dean Feiock -- Stock 5002 |
