Old 01-06-2012, 11:50 PM   #1
R. Thorne
Liked 101 Times in 34 Posts
Default globalwest delalum rear leaf spring bushings
Anybody installed any of these? Front and rear (leaf spring) measure about .040" larger than hole in leaf spring. Rear upper shackle bushing (to body) is about .020" larger than hole in body. This seems like an unusually tight press fit to me. I am planning to call globalwest Monday, but thought some of you might have experience with these bushings. Also, am I going to be faced with the same situation with the front end control arm bushings from globalwest if I decide to use them? Thanks, Ron.
R. Thorne is online now   Reply With Quote
Old 01-11-2012, 12:28 PM   #2
Todd Bailey
Liked 33 Times in 17 Posts
Default Re: globalwest delalum rear leaf spring bushings
Ron,
Keep us posted on what they say. I got the rear bushing kit from them and wasn't too impressed.
Todd Bailey is offline   Reply With Quote
Old 01-11-2012, 02:01 PM   #3
vonzipper396
I put kit #108sh in my 69 w stock multileafs.Pressed in hard but doable.helped improve my 60ft i feel.
vonzipper396 is offline   Reply With Quote
Old 01-11-2012, 09:55 PM   #4
R. Thorne
Global West verified the specs and seemed surprised about the dimensions I gave them, said they should have about .015-.020 press fit. After some research on the net, I learned that others have had the same issues and can only speculate that their springs (globalwest) are made to a slightly larger (.020) spec than oem. Competition Engineering's aluminum bushings are smaller than GW and would fit oem springs much easier (.020 press fit). I decided to go ahead with the GW, however, as they control the lateral sway better (to help with tire clearance when turning corners with a locked rear end). The key to installing them is to separate the spring curl (about 1/8 of an inch) with a screwdriver and then tap in a pry bar to hold it in position while you are pressing the bushing (I did it with my large shop vise as I don't have a press) . I then used some old bearing races to finish installing them after they were pressed flush with the spring. The frame bushings were a piece of cake ( only about .020 press fit, remember) with threaded rod and plates and bearing races, again. GlobalWest assured me that there would be no problem with the front end bushings, but they also acted as if my situation was peculiar. They also refused to give out specifications on their bushings. I think I am going to go with afcos on the front. All in all, not the most enjoyable experience I have had with a manufacurer. Hope this helps. Ron.
