My .02 cents worth, Really well though out answer,and humourous. Seems as if todays stocker engine pulls alot more RPM 's, thus your attention to valve springs.
I am not trying to regress or anything,but years back it was very rare to see a stocker scatter an engine. Seems a little more common now, I think. Anyway thanks for your response,I hope we hear from some more of the guys. ed |
Liked 1,821 Times in 413 Posts
Eddie,
It is typical to see close to 8000 RPM in Stock Eliminator these days, some are going higher. Valvetrain in Stock is absolutely critical, valves, valve springs, pushrods, and rocker arms are all parts that require close attention. Of course, the new rule allowing roller rockers will help on the rocker arms, if they ever get the rule clarification done and published. With aftermarket rods, pins and pistons, the short block life is good, especially for small block Chevy engines. A leak down test will often "lie" to you. I've seen engines that "leaked good" that were way down on power due to blow by, and engines that "leaked bad" that made enough power to set a record. Fortunately, ring seal and ring life is a lot more of a science now, and has improved greatly.
Alan Roehrich 212A G/S |
Just like in the 70's...cut open the oil filter!
Aftermarket rods have helped rod bearing life tremendously and saved a lot of money for the racer. Running the required ring land spacers and thin rings have helped with power and longevity of the rings. Don't forget the rings are usually back-cut for less radial tension but seal better with the newer facings and materials. Stainless valves will last longer too. Just like the 70's, check valve lash for problems. Pay attention to MPH changes.
Jeff Lee 7494 D/S '70 AMX |
Liked 67 Times in 30 Posts
All the mechanical answers have been great but you can also track your performance
in relationship to your competition, get a qualifying sheet at each race and compare your qualifying times to everyone else and see if your changing more than others. If you have a few racing buddies you see frequently at the track you can compare et slips from week to week and know where you stand, then if something is abnormal get out the tools and start checking things out.
Ron Mattson 5015 STK |
Liked 332 Times in 180 Posts
Ditto on changing stressed parts at regular intervals eliminates many problems
check oil & filters for particles leak down test as well as blowby testing to check ring wear among other things do not be afraid to take off the valve covers and give it all a good lookover for particles,broken springs ,rocker arm alignment , water leaks,etc--also turn engine over by hand while looking in these areas check valve retainer/locks/caps appearance ,spring condition and pressures dynos only tell you part of the story track performance is the true test--check chassis/tires etc regularly too compare your performance with another similiarly classed car if possible see if when you do make changes if in relation to the other cars what happens faster/slower keep records on every run-- your engine settings/weather etc so you can go back in future situations to compare that performance against a known condition in the past |
Banned
Buy a quality blow-by meter carry with you to the races very easy to use with wet sump system, little harder with dry sump, any thing over 2 cfm take engine apart and fix it.
Liked 244 Times in 26 Posts
Use going down the track or just at idle in the pits. Never thought of it but good idea.
