Old 12-04-2011, 11:25 AM   #21
Ed Sroka
Default Re: 5TH Gen COPO Camaro
Thanks Mickey. Couldn't agree more although I didn't want to be the first to say it here. The COPO version certainly doesn't help. The aspect ratio is simply miserable.
Ed Sroka is offline   Reply With Quote
Old 12-05-2011, 11:51 AM   #22
Dirk Olson
Liked 172 Times in 46 Posts
327, 5 speed cross, it over like a comp car at 10,400, could run high 8's
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 12-05-2011, 12:27 PM   #23
new az stocker
The last good looking Camaro was the first generation...............................
new az stocker is offline   Reply With Quote
Old 12-05-2011, 12:46 PM   #24
jmcarter
jmcarter's Avatar
Liked 3,174 Times in 971 Posts
I may be a Mopar guy but agree with you 1000%. Truly a classic. I would love to have one if they weren't so expensive.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-05-2011, 08:53 PM   #25
Troy Pourciau
WHOOO 9's right out of the box.
The Chevrolet COPO Camaro development group was in Bradenton, Fla., with the prototype version of the factory-prepared race car making shakedown runs on Monday. The group kept the car’s performance under a shroud of secrecy as they made several runs with the scoreboards turned off.
Longtime class racer Mike Pustelny is the driver putting the new Chevrolet through its paces. We are told the car has already made it into the 9's despite a mild launch. A source tells CompetitionPlus.com that this COPO was built at Pustelny's MPR Race Cars shop with direction from Russ O'Blenes, Robin Wright, and Mark Kent of Chevrolet Performance.
PHOTOS: TESTING IN DECEMBER
Old 12-05-2011, 09:08 PM   #26
hemidup
What's that thing weigh? Heard the NA/427 will fit into A/SA.
Jerry Williams
NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's.
hemidup is offline   Reply With Quote
Old 12-05-2011, 09:46 PM   #27
Troy Pourciau
427
327/2.9
327/4.0
Suggested class
A Stock
AA Stock
A Super Stock
Cubic inches
427 (7.0L)
327 (5.3L)
327 (5.3L)
Block
LS7
LS9
LSX
Block material
Aluminum
Aluminum
Cast iron
Bore x Stroke (in.)
4.125 x 4.100
4.065 x 3.150
4.065 x 3.150
Crank
Forged steel
Forged steel
Forged steel
Rods
H-beam
H-beam
H-beam
Pistons
Forged dome
Forged dome
Forged dome
Compression ratio
13.5:1
10.2:1
10.2:1
Heads
LS7
LS7
LS7
Induction
natural
boosted
boosted
Intake
Holley 2.9L
Whipple 4.0L
Whipple
Camshaft type
Hydraulic roller
Hydraulic roller
Hydraulic roller
Cam duration (deg.)
233/276 @ 50
244/255 @ 50
244/255 @ 50
Cam lift (in.)
.595
.650
.650
Old 12-05-2011, 10:57 PM   #28
rawhide
Liked 7 Times in 5 Posts
Originally Posted by Troy Pourciau View Post
427
327/2.9
327/4.0
Suggested class
A Stock
AA Stock
A Super Stock
Cubic inches
427 (7.0L)
327 (5.3L)
327 (5.3L)
Block
LS7
LS9
LSX
Block material
Aluminum
Aluminum
Cast iron
Bore x Stroke (in.)
4.125 x 4.100
4.065 x 3.150
4.065 x 3.150
Crank
Forged steel
Forged steel
Forged steel
Rods
H-beam
H-beam
H-beam
Pistons
Forged dome
Forged dome
Forged dome
Compression ratio
13.5:1
10.2:1
10.2:1
Heads
LS7
LS7
LS7
Induction
natural
boosted
boosted
Intake
Holley 2.9L
Whipple 4.0L
Whipple
Camshaft type
Hydraulic roller
Hydraulic roller
Hydraulic roller
Cam duration (deg.)
233/276 @ 50
244/255 @ 50
244/255 @ 50
Cam lift (in.)
.595
.650
.650
when I take my shoes and socks off and do the math the 427 with a 4.125" bore and 4.100" stroke is 438 cubic inches. The Factorys are even taking care of the cheating for us now.
regards, Roland
rawhide is offline   Reply With Quote
Old 12-05-2011, 11:08 PM   #29
Ed Wright
Ed Wright's Avatar
Yep, your correct. 438"
Ed Wright 4156 SS/JA
Old 12-05-2011, 11:14 PM   #30
Pvt Parts
Pvt Parts's Avatar
regards, Roland
Some prefer to call it "Pushing the Envelope". 8-)
