Old 12-03-2011, 10:50 PM   #1
nolongerracing
Liked 72 Times in 27 Posts
Default Re: Is this legal?
Sway bar = panhard bar. Locates the rear end side-to-side. Anti-roll bars control body roll. Two separate components. Body roll & side-to-side sway are two different things.
At least that's according to GM shop manuals.
I'm confused with your answers....if sway bar = panhard bar, why does my cars have both? These are mid 80's Camaros. They have a bar that connects the body to the rearend housing...panhard. They do not have a bar that connects the lower contol arms. They have a bar that connects to the body and the rear end. Is that an anti-roll bar? If so, why is it not legal to replace it with the aftermarket anti-roll bar?
nolongerracing is offline   Reply With Quote
Old 12-03-2011, 11:08 PM   #2
Ed Wright
Ed Wright's Avatar
As I said, the bar that bolts between the F body lower control arms is an anti roll bar. The bar running from the driver's side end of the rear end housing to the bracket on the frame, passenger side, prevents side-to-side sway. Some people tend to cal the anti roll bar a sway bar also. That is not accurate, but you go ahead and call it what you want.
Ed Wright 4156 SS/JA
Old 12-03-2011, 11:47 PM   #3
nolongerracing
Anti-roll, anti-sway or stabilizer (according to GM parts) are all the same. The purpose of the panhard bar (axel tie rod according to GM parts) is to only keep the housing centered in the car. It is not a side to side "sway bar". So if it came with an anti-roll, why can't it be replaced with an aftermarket unit?
