Liked 68 Times in 41 Posts
is sway bar and anti roll bar the same thing in a f-body?
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay Last edited by dartman; 12-02-2011 at 01:02 PM. |
No sir.
Ed Wright 4156 SS/JA |
Liked 9 Times in 3 Posts
Mark Markow 171 ss/tb |
Sway bar = panhard bar. Locates the rear end side-to-side. Anti-roll bars control body roll. Two separate components. Body roll & side-to-side sway are two different things.
At least that's according to GM shop manuals.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 12-02-2011 at 10:41 PM. |
And still... no one can post where the rule book states that you CAN'T weld in an anti-roll bar......
Shawn Allsup K/S 718 |
i'm not looking for an argument but, i guess i'll have to disagree with gm on that one . how in the world a (sway bar = a panhard rod) is beyond me. i guess a camaro with a front sway locates the front end? LOL. in my opinion a sway bar and a anti roll bar are the exact same thing. they both control body roll. i guess technically it should be called an anti-swaybar
Mark Markow 171 ss/tb Last edited by Mark Markow; 12-02-2011 at 10:58 PM. |
Mark, sway is side-to-side. A panhard bar locates/centers the rear end under the car side-to-side, but will not control body roll.
That front bar is anti-roll also.
Liked 72 Times in 27 Posts
Why do my 2 stock street Camaros have both a panhard bar and a sway bar on the rear if both do the same thing?
Liked 165 Times in 59 Posts
i have built a couple of sway bars for customers and made sure they where bolt in,,it should be good but if your welding in supports on the frame like in the "chevy artical" i wouldn't think it would fly gmonde
Liked 8 Times in 3 Posts
You need to go back and look at the pictures again - the part that welds in under the floor is designed the reinforce the frame under the rear roll bar braces. The anti-roll bar bolts to those braces. A technicallty? Maybe but acceptable yep. The part has been around for years and is under several national & division winning Camaros & Firebirds including a recent world champs car. It's been looked at by tech guys in several of the divisions - never a problem.
