Old 11-05-2011, 09:08 PM   #101
Jeff Lee
Jeff Lee's Avatar
Default Re: Roller Rockers in Stock
Originally Posted by Bill Grubbs View Post
Using GM rocker arms, we have acually broken 3 rocker arms in 5 years, found probably 8 more cracked. Rocker arms are not a problem for us, but we only run a few races a year.
Cracked is broken. Thats 11 broken rocker arms in five years and you have raced "a few" races a year. If that was two races a year, that would be ten races in five years. That's .9 broken rockers per race.
I remember one year Scott Pearson could only afford to race two national events. He won them both. True he races SS/JA but there are many Stock racers like yourself that can't afford to attend many races. Sure would suck if you broke a rocker in a final round! Even first round breakage would cost you a lot of money.
Jeff Lee 7494 D/S '70 AMX
Old 11-05-2011, 09:21 PM   #102
Liked 1,821 Times in 413 Posts
A few?
How many Division 2 races did you and Brenda skip this year Bill? We didn't make the tour this year, we'll be back next year.
We have never broken a rocker arm, not in 6 years, although this year was real short. We've broken one 7/16" rocker stud, the poly lock killed the entire engine, including the block. We have only run near 500 passes on one set of rockers, and maybe 300 passes on the other set. No, we ain't as fast as some, but we haven't lost too many heads up races, we've got 2-3 class wins, and we usually go a few rounds fairly often. It may not be a rocket, but it ain't a slug, either.
Old 11-05-2011, 09:59 PM   #103
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
How about the shaft type rocker guys..................
Jesel or T&D......
Take your pick
No potential performance gain.......Give me a break
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 11-06-2011, 09:00 AM   #104
Greg Hill
Liked 279 Times in 68 Posts
It's my understanding that the shaft type rockers are not legal for stock.
Greg Hill 4171 STK
Old 11-06-2011, 09:30 AM   #105
Bub Whitaker
so who makes a roller rocker that is shaftless?
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 11-06-2011, 10:03 AM   #106
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
The better question is:
Why would you want a roller rocker that is shaftless?
Old 11-06-2011, 11:53 AM   #107
Greg Hill
Stud mounted rockers are what I was told and that jessel or t&d rockers are not legal. I think you all know what i meant.
Greg Hill 4171 STK
Old 11-06-2011, 01:45 PM   #108
Woodro Josey
Liked 3 Times in 1 Post
So now, does it have to be a certain mfg or is any mfg legal, for the stud mount rocker?
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 11-06-2011, 01:45 PM   #109
Ed Myers
News flash !! Some engine's come with a shaft from the start ! Some Ford
FE and some GM and Dodge and the list goes on .
Ed Myers is offline   Reply With Quote
Old 11-06-2011, 02:33 PM   #110
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
I was wondering when someone would finally point that out !
I'm a Chevy guy... pre 73 that is. No shafts there. However, to my knowledge, don't most Mopars of that earlier era, have shaft rockers ?
I'm sure it's safe to assume that the new rule will at least madate that the engine has to possess the original rocker configuration.
Does that mean that the shaft-rocker engines will have an advantage ?
perhaps a little
That's the way it is.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
