1988 mustang 2900 lbs w/driver c4 tranny,5400 8 inch conveter 28x10.5
mt slick stock style suspension 4.56 gear aftermarket control arm and tubular k member. Car ran 10.29 @132.12 with 1.49 60 footbraking. 349ci smblk ford apox. 525 hp. Just wondering if the 60 ft can be improved and maybe a number I should be working toward. Thanks. |
Liked 330 Times in 178 Posts
you can set up a car to many different things---60 foot---- 1/8th ---1/4---ET--MPH what ever --- just cuz ya have a tremendous 60 foot time doesnt mean that the 1/4 is going to be fantastic too---now if the exact same or similiarly classed car car had a 1.39 vs. your 1.49 and the same 1/4 ET/MPH then you need to pick up your 60 a bit cuz a rule of thumb is for every .01 of 60 double it at the other end and take that time off your 1/4 mile ET and that's what your corrected ET should be--- for example 1.49 =60 and the 1/4 ET is 10.20 so if you could pick it up to say a 1.45=60 your 1/4 et should be .03x2+.06 new ET should be 10.14--- not carved in stone too many variables to consider but I hope this will give ya an idea
Liked 5 Times in 3 Posts
What low gear you have in the C4?
Liked 70 Times in 29 Posts
What RPM are you leaving at when foot braking?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 222 Times in 72 Posts
Aa Greg says Low gear in the C4 2.92 or 2.75 is the common low gear sets for these. If you are at a stock ratio you can inprove a bunch. My Fox body mustang stoker is simular in wieght and rear gear mine is 4.88 and I run the 2.92 first gear in the c4 has had the best 60' of 1.52 et are 11.97. Do you use a 2 step also?
Any nitrous? Mine is a stock c4, 4.10 gear, 3120 lbs. with me, no nitrous. Usually 1.50 - 1.52 with 2 step at Bandimere runs 11.20's. San Antonio Nitro Jam last spring consistant 1.42's no 2 step. Footbraking at about 2000 rpm and stab the throttle. Ran high 10.50's -60's. Best 60' Saurday morning 1.405. Lots of fun.
![]() Jeff
Street legal 64 Falcon Sprint with 410W ![]() Stock - Super Stock fan |
stock gear set 2.48 low gear ?
2500 rpm launch no nitrous no 2-step/ non electronic class Thanks for your replies |
I forgot to add with mine I never saw 126 mph. Best was 125.77 mph. I think 132 mph is a lot for that et.
![]() Jeff
You know, I keep hearing about the 60" improvements multiply. I must be doing something very wrong. Mine picks up in the 1/4 mile the same as the 60' improves.
Never more. When I first started trying to play with mine, after being away over 30 years (no 60' or other incremental times back then) I noticed that when I first tried to bracket race a little. So, I asked my old friend Mike Edwards about that, He knows more about things like that than anybody I know. He asked me "How could ETs improve more than 60' times?". I told him "I don't know, I just keep seeing guys talk about that on the internet." His reply was I needed to stay off the internet. LOL! A car with enough power to run 132 MPH should at least 60" in the low 1.30s even foot braking it. 10.29 ETs for a normally aspirated 132 MPH car is a bit off. Should be very low tens at least. Fixing the 60' times would take care of that.
Ed Wright 4156 SS/JA |
Liked 544 Times in 213 Posts
I have a friends car to drive and it was mine a few years ago.
It's a '97 Firebird LT-1 Stocker. He made some improvements since I owned it and it's a little faster now.... When I owned it I think my best 60' was around 1.32 or 1.34 and I ran some 10.50s in real good air.. A few weeks ago I had a 1.29 60' and ran 10.53 carrying more weight than when I ran the car.....I also had some 1.31-1.32 60's a week earlier at my local track.....Car weight was about 3150lbs. All runs have always been off the footbrake....no 2 step... Big wheelies are pretty std on any of these cars and this one gets up pretty good at times.......
