Guest
Posts: n/a
A rule change to roller rockers will kill the "stock legal stock rocker" industry. Time to sell off your inventory before it's worthless.
Liked 19 Times in 7 Posts
I can tell its the "off season" for some people because all the hens have their feathers in a ruffle. Whoever started this post should have waited a few more weeks
![]() I used to run crane nitro rockers and moved to rollers when it became legal in IHRA....not because of failure, because I had a set on the shelf. And I didnt see any change in ET or MPH. So a performance advantage is nill if you are going rocker to rocker with no other changes. And if you cant aford the rockers dont change them, if your stuff works and doesnt break leave it alone. Rollers rockers have been legal in IHRA for a few years now and I dont think the rocker company is going to suffer from not making stamped steel rockers. Their is probably less money to be made on a stamped "aftermarket" rocker because of the tooling involved to make the part VS machining an aluminum bodied rocker. They change the rocker arm rule and you guys start talking about that killing Stock Eliminator and then go on to talk about other things like tires and mini tubbing and inboard springs....take it easy. You guys should know by now any opinions stressed on this or any message board will do nothing to change any sanctioning bodys mind about the rules. Just my 2 cents. And NHRA and IHRA racers are not the only ones using "stock style" rockers.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A Last edited by CrateCamaro; 10-28-2011 at 12:39 AM. |
It would help me out though! hehe! Im sure i could run the index without rollers or a square cam
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Liked 130 Times in 42 Posts
Just need to put the red lines back on and we're about to the point of runing with these guys.
http://www.fastraces.org/ |
Liked 16 Times in 11 Posts
whole different cam for that deal
Bob Pagano A/SA |
Guest
Posts: n/a
Those guys have super gas engines in stock appearing car with bias tires. Sound like a blast
Liked 536 Times in 110 Posts
I don't mean to help jump the thread off-track, but I was at one of the F.A.S.T. (Factory Appearing Street Tire) races about a year ago at US-131 Dragway. I saw a couple of the cars running 130+ MPH on basically bald red lines, which is probably a recipe for disaster. The engine's looked stock, but internally were mechanical roller with 500+ cubic inches and sky high compression ratios.
Jim Kaekel 3836 STK |
Little info from experience with roller rockers on a FE Ford stocker, back to back with "stock" rockers verse's Harland Sharp roller rockers, on the track.........= 0, nothing...I don't maybe I needed to change the jetting and timing and collector choke size and tire pressure and piston rings and .....to take advantage of the rollers.....I dunno....
67 Ford Fairlane F/SA 749 |
Liked 68 Times in 41 Posts
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
