Old 10-21-2011, 07:00 PM   #1
bogger01
Default Re: new to bracket racing
i see.but how big is too big.like i said i have a small block (357 c.i.) with reworked 040gm heads and a performance cam of an unkown make and size and a factory aluminum intake.i have been told 650 cfm was as big as i could go.any thoughts
bogger01 is offline   Reply With Quote
Old 10-21-2011, 07:03 PM   #2
Phillip marvetz
Phillip marvetz's Avatar
850 dp.
2009 V/SA Record Holder
Old 10-26-2011, 11:18 AM   #3
Bill Baer
Smile Re: new to bracket racing
There is a formula :Racing carb cfm = rpm x displacement / 3456 x 1.1 so it depends on how high your going to twist it @ 7000 RPM it comes out 795CFM so I would use a 750 the vacumn secondary (3310) being the easist to live with on a street car of the double pumper for race use only.
Now if you do the math an spin it 10000 RPm you need about 1136 CFM and in that case a tunnel ram and two carbs would be the ticket.
Note there are a lot of other varibles to be considered cam size ignition timing (intial lead and curve speed) collector length and torque converter stall and keep in mind that formula is for a dedicated race car.
The street formula is Street carb cfm = rpm x displacement / 3456 x 0.85.
Hope this helps.
Old 10-27-2011, 12:12 PM   #4
Phillip marvetz
Hope this helps.
That is fine for a street car, If you want a bracket car that will repeat the 850dp is the way to go.
