Monte,
Thanks for the thoughts. Kevin, I'm running MSD 8.5mm plug wires. No solid core. Arnold, I checked the fuel filter when I drained the fuel system, and all is well. I can fill a gallon in about 23 seconds. I had previously been told that anything under 25 seconds was ok. Regardless, my problem is occuring when I'm barely tipping the throttle. I would think that even if fuel flow was insufficient for racing, I'd still be able to drive it around the block. Bob, Not a dumb question, and yes I did install a new 4-7 cam, and yes I've checked and rechecked the wires about 2 dozen times. I always assume the possibility that I've done something foolish. -Ben |
