Old 10-10-2011, 11:19 PM   #11
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Oil pressure @ performance?
When I change from straight weight 30-40w conventional race oil used for break in to synthetic Amsoil 5w-20 Dominator, not only does my oil pressure drop, I have to turn down the idle rpm!
I forgot the exact #'s on both, but it's obvious and gets your attention.
Old 10-11-2011, 08:29 AM   #12
Ed Wright
Ed Wright's Avatar
Default Re: Oil pressure @ performance?
Originally Posted by Kenney Kelley View Post
Danny this might be some help. http://www.superstockforum.com/showt...threadid=11549 Kenney Kelley
I have one of Larry's low volume pumps in my SS LT1. I set the relief spring to 40 psi. 40 psi @ 8500, cold idle is also 40, hot idle is 20 to 25 psi with 5W 20. Bearings always look like new, except for one time I tried Joe Gibbs zero wt. Saw some wear on 4 rod bearings. Won't try that again. Zero-5 (Used to be called "Race9") Royal Purple does just fine. I've never used over 40 psi through the lights. Used to use 30 psi in my Stockers. You have to have everything else right. Even with this pump the Royal Purple was worth 12 hp on the dyno.
Ed Wright 4156 SS/JA
Old 10-11-2011, 09:22 AM   #13
Joe Schaechter
Joe Schaechter's Avatar
Liked 13 Times in 4 Posts
Here is another low drag pump option for a small block Chevy
http://schumannsdynamicperformance.c...43/SBC/LVDR5/8
Joe Schaechter 3168 STK
Joe Schaechter is offline   Reply With Quote
Old 10-11-2011, 07:16 PM   #14
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
I remember when putting 454 oil pumps on sb's was all the rage. This post has me wondering if you can run a sb pump on the 454? Special shaft???? Stock shaft??
72 cutlass
Daran Summerton is offline   Reply With Quote
