Old 10-10-2011, 10:00 PM   #1
Kenney Kelley
Liked 72 Times in 36 Posts
Default Re: Oil pressure @ performance?
Danny this might be some help. http://www.superstockforum.com/showt...threadid=11549 Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 10-10-2011, 10:01 PM   #2
Tom Meyer
Liked 354 Times in 120 Posts
Danny you have PM
Tom Meyer 5240 SS Stock ???
Old 10-11-2011, 08:29 AM   #3
Ed Wright
Ed Wright's Avatar
I have one of Larry's low volume pumps in my SS LT1. I set the relief spring to 40 psi. 40 psi @ 8500, cold idle is also 40, hot idle is 20 to 25 psi with 5W 20. Bearings always look like new, except for one time I tried Joe Gibbs zero wt. Saw some wear on 4 rod bearings. Won't try that again. Zero-5 (Used to be called "Race9") Royal Purple does just fine. I've never used over 40 psi through the lights. Used to use 30 psi in my Stockers. You have to have everything else right. Even with this pump the Royal Purple was worth 12 hp on the dyno.
Ed Wright 4156 SS/JA
Old 10-11-2011, 09:22 AM   #4
Joe Schaechter
Joe Schaechter's Avatar
Liked 13 Times in 4 Posts
Here is another low drag pump option for a small block Chevy
http://schumannsdynamicperformance.c...43/SBC/LVDR5/8
Joe Schaechter 3168 STK
Joe Schaechter is offline   Reply With Quote
Old 10-11-2011, 07:16 PM   #5
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
I remember when putting 454 oil pumps on sb's was all the rage. This post has me wondering if you can run a sb pump on the 454? Special shaft???? Stock shaft??
72 cutlass
Daran Summerton is offline   Reply With Quote
