Old 09-12-2011, 10:18 PM   #1
Liked 1,917 Times in 431 Posts
Default Re: rebuilding front end in 68 camaro
Global West Del-A-Lum control arm bushings with grease fittings, Moog or TRW control arm shafts, and TRW or Moog ball joints, with the circle track style extended upper ball joints. You can also use the trick adjustable tie rod ends that allow you to correct bump steer. Those were even made legal for Stock Eliminator this year. The absolute best shock is the Santhuff, if you're going to use them, you'll want to modify the lower control arms while you have them off of the car. Some use Moroso Trick Springs, others just use a stock replacement small block "w/o A/C" spring.
Old 09-13-2011, 09:34 AM   #2
Greg Hill
Liked 279 Times in 68 Posts
If you don't want to go to the expense of the Global West a-arm bushings try the afco steel ones. A lot less money and the front will operate freely and smoothly.
Greg Hill 4171 STK
Old 09-13-2011, 03:08 PM   #3
racer913
thank you for your help
racer913 is offline   Reply With Quote
