#1 | |
Liked 20 Times in 15 Posts
The gear ratio in my combination which is the 265 single four barrel needs to be no less than 6.20 with some apparently running as low as 7.17. Allan |
#2 | |
Liked 6 Times in 4 Posts
Buick had a very similar transmission called "Triple Turbine Dynaflow," during the same period of time.
Bill Last edited by bill dedman; 08-15-2011 at 12:50 PM. |
Liked 44 Times in 27 Posts
![]() ![]() M68
"The more corrupt the state, the more numerous the laws." - Tacitus |
I raced my '57 J/S car for a few seasons. one time I pulled the rockets out of the hood, and made a full sheet of aluuuuminuuuum to go from fender to fender and rad. to firewall, with only a hole over the carb. got by for a while till someone, at the big end noticed how the hood 'puffed' up. must have really packed the air in. funny at the time.
Rod in AZ |
Liked 784 Times in 196 Posts
My first race car was a '57 150 business coupe with a 283 two barrel. Raced it one year before they outlawed the 4-speeds. The trick of the day for the rear end was to use MoPar side gears in the positraction case and modified MoPar 30 spline axles from 8 3/4 rears. That stopped the axle twisting for me. SS&DI had an article about it.
Liked 1,002 Times in 203 Posts
Was looking in the NHRA blue print specs for the 1957 Chevrolet engines.Do not see a listing for the acceptable intake manifolds?
yes, the Chevy [57-64] posi units were the same as MoPar units, with the exception that the Chevy used 17 spline axles [just less than 1" dia.] and the MoPar posi used the larger 30 spline axles. took 4 gears to complete the swap. back in the day, the backing plates were the major hurdle. today, of course, Moser could whip out a set of much better custom axles using all Chevy parts. and yes light weight. years ago I meet a SS racer from BC,Canada who had a red '56 SS/NA with a 2x4 PG with Brake and he actually went back to the Chevy/MoPar rear. he was not easy on it.
Rod in AZ |
Liked 11 Times in 8 Posts
