Old 08-09-2011, 11:39 AM   #15
Altronics
Sponsor
Altronics's Avatar
Liked 63 Times in 11 Posts
Default Re: Single channel O2
O2Alert features single or dual widbands plus RPM and Battery voltage standard. Has Auxially inputs for EGT, Drive shaft RPM, and Pressure/Temperature/ voltage.
Data can be read back on screen or comes with software to download to a computer and graph/overlay.
THis system also features automatic recording capability, so that there is NO user interaction required to start recording. You can sit in the lanes for hours and then make your run and do not need to remember to push a button!
Also features AFR average which is very useful in determining what tune up change has effected performance. In carbed applications fuel slosh can cause fluctuations in AFR. I like to be able to look and the entire run and see not only what the AFR is a specific points but more important what the average AFR is.
Also, This is a CONTINGENCY item!
See our website for more info www.altronicsinc.com/pages/o2alert.html
Fred Bartoli
847-923-0002
Altronics is offline   Reply With Quote
