#21 |
Liked 101 Times in 27 Posts
Let me dive in for a question again after reading all of this as far as application...... added 200 lbs to change classes...car was running well in lighter class.....do I need to get the converter adjusted to accomodate the heavier class ???? ( 3200 to 3400 lbs ) Also changed the rear gear from 4.88 to 5.00.....rpms at stripe did not change if that means anything...any comments ????
#22 |
Liked 7,780 Times in 1,743 Posts
Well I hope that I don't get raked over the coals for over simplifying this but by adding 200 lbs. you would make the converter "act" looser but by adding the gear you would make it "act" tighter. Clear as mud.
#23 |
Are you saying the gear change should have put the converter in the same operating mode as the lighter class with the shorter gear ???
#24 |
Liked 880 Times in 311 Posts
Yes, that is what he is saying and your finish line RPM is telling you. Didn't you see where I said if you change the low gear, rear gear too, the way the converter works will change? Your gear change was 2.4% so the steeper gear made the converter work tight enough to overcome the weight and the extra rpm the gear ratio should give you at the finish line.
Adger Smith (Former SS) Last edited by Adger Smith; 07-28-2011 at 07:01 PM. Reason: sp |
