Liked 759 Times in 379 Posts
Post all 3 time slips, both time trials and first round
Jason Whisman |
Looks like the second time slip should have been the fastest/quickest to me. Does the direction of the wind change much? Is the carb a vacuum secondary or a double pumper?
2009 V/SA Record Holder |
it's a double pumper and no i don't notice it changing much. I'm starting to think it's just me in the car. Maybe i am letting it bother me too much.
Jason Whisman |
The carb is smaller than I would use, If the weather changes it will affect the small carb more. Does it have a hydraulic cam?
Just a suggestion.....Make sure you stage the car the same every run and the pedal to the left of the throttle is your friend! What viscosity oil are you running?
Shawn Blair 6383 SS 634 STK Last edited by Shawn Blair; 06-21-2011 at 01:23 PM. |
The cam is a old hemi grind cam. It was part of Dad's old small block stuff he put in the motor, but i don't know anything about it. Oil is 10W 30. I have a 2 day race this weekend i'm going to do some more testing hopefully it's just me flipping out.
Jason Whisman |
is there a metter that i can buy for air temp and denisty
The carb size is fine. You do not need a larger one.
What's the list number on the carb? What track are you running at? Do you have any idea what the DA was on any of those passes? |
Are you running slicks? If not, I'd suggest you try them.
What's the camshaft duration @ .050? If it's got any kind of performance camshaft, you should be turning it more than 5000 rpm. It won't be consistent if it isn't revved. |
