Old 06-07-2011, 06:03 PM   #1
Robert Swartz
Robert Swartz's Avatar
Default Re: SBC replacement main caps - Stock
Thanks guys. You answered my question, in spades. There's a lot of very good information there.
Yes, it is an 010 block with the 020 on the inside of the timing cover. It is a 4 bolt main block. I believe, I'm going to put this block back and save it for a bit. I'm now armed with some good information and have an idea of what it will take to make this an acceptable part.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 06-07-2011, 06:16 PM   #2
trmnatr
The 010/020 I have, is thick enough to go 4.100" safe, IIRC the thrust walls were at least .150" @ 4.1" bore, I'm only 4.061"-4.0615"
Not all of them are though, some were just very good and some were not.
IMO, all this work needs to be done to the blocks regardless which casting number
trmnatr is offline   Reply With Quote
Old 06-07-2011, 06:24 PM   #3
trmnatr
I will give you an example of what an engine did on the track I did, it was our team engine (then he left the team, it was fair for him to leave with a running engine IMO)
1980 Camaro @ 2,850 pounds race weight
Powerglide with 5,200rpm stall
12 bolt with 4.88 gears and Mickey Thompson 32x14 Tires
Engine, GM 509 Block, 4 bolt main (weaker 400) with GM main bolts
- GM block, filled with Hardblok, all mods as suggested below
- GM Nodular Iron Crank
- King Bearings set @ our clearances
- Flat Top Forged Pistons @ .0075" Clearance
- 1/16" 1/16" 3/16" rings
- Our final gone finish we do
- GM 291 Camel Hump Heads, 2.02"/1.6" valves installed, bowl ported due to larger valves, exhaust runners ported to smooth out, chambers are not ported, intake runners are not ported
- Crane Solid Cam 292/300 @.020" 256/264 @.050" .545"/.563" 105° lobe center installed at 102°
- 1.46" Crane Springs 160 seat and 400 open
- Victor Jr.
- 1000 Annular Modified by us
In the Camaro it ran 10.teens @ 131-133mph every pass. Some videos below. When he decided to part out on his own, he took the engine and put it in the Dragster @ 1,750 pounds race weight for some 8.60/8.70 consistent ET's
Here are the videos,,,
Pass
Cold Start
Running Clean
