#21 |
Liked 13 Times in 7 Posts
You need to check on a Billy Lynn metric trans. He's a lot more reasonable on price that McClay and his stuff will work just fine in I/SA.
Richard Grant 4988 STK |
#22 |
Liked 66 Times in 37 Posts
Well tested Sat. night and everything went well, lost in the final of the index race. Trans made car much easier to drive leaving on the mat. Unfortunately the car still only went 1.80-1.81 60 ft. The car just will not react. The front end does not move at all. I believe I am WAY under geared but I have to work on the suspension. Any front spring recommendations? Can I remove front strut rods to free up the front. I have CE 90/10 shocks on loose setting. Car just is not working.
72 cutlass |
#23 | |
Liked 1,831 Times in 415 Posts
Alan Roehrich 212A G/S |
#24 |
x2
Alan Warman STK 4107 |
#25 |
No WAY! I think closer to the 330. I am beginning to think 28" slicks now
72 cutlass |
#26 |
Daran, what's in the engine? Is it making any power?
#27 |
Liked 5,125 Times in 1,953 Posts
NO! They are the triangulating point for the lower A-arm.
What's done to the rear susp.? If it's too stiff, the front won't lift with that long wheelbase. I never had one of those cars that wouldn't lift the front end, with stock springs. It sounds like the engine combo is messed up . Need details ...Cam ,manifold, carb modifications , headers etc.
#28 |
Engine is by no means Stellar!!! I built it
![]() P.S. it took a torch and a 5 ft. pipe to break the strut rod nuts loose ! LOL
72 cutlass |
#29 | |
I'm surprised nobody else told you that yet . Everybody must want to watch the fun... Now, if you had a FWD conversion, you'd get carte blanche from NHRA (No Hot Rods Allowed)
#30 |
http://www.globalwestperformance.com...trut-rods.html
Mark it's all bolt on so I don't forsee a problem. I believe your right on the gearing and the rear suspension being bound up (Tight) I truly wish I just had the factory rear arms with the factory springs at this point. Something is dead wrong.
72 cutlass |
