Old 05-17-2011, 02:03 AM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question Front brakes 67 Camaro?
Well after 24 years Dad gave me the Camaro he bought me to drive to school (after driving it home it was to fast for me ). Now to do some upgrades....the car was factory SS 396/325 car....manual drum brakes. I want input on changing it to manual front disc.
Old 05-17-2011, 08:55 AM   #2
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Default Re: Front brakes 67 Camaro?
Areospace has good stuff for the price. Wilwood works well also.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 05-17-2011, 09:03 AM   #3
scott helms
scott helms's Avatar
Smile Re: Front brakes 67 Camaro?
We use Aerospace on Kevin's SS camaro and my SS chevelle all around. If you need some help,willwood,strange etc.I'm W.D. with all of them, all are better than factory manual drum or disc.
SCOTT HELMS Stk,SS 2540
scott helms is offline   Reply With Quote
Old 05-17-2011, 12:30 PM   #4
Dave1695
Liked 15 Times in 11 Posts
Give Stainless Steel Brake Corp a call, they have a four piston Comp caliper kit that bolts right on your drum spindles, uses the drum hub and is light weight.
Dave1695 is offline   Reply With Quote
Old 05-18-2011, 10:27 AM   #5
Jim Parsons
Liked 197 Times in 32 Posts
Over the winter I bought the Aerospace front brake kit for my NOVA through JEG's, I know several of my race friends that have their stuff and had good experience. However that was not mine; from the smart a*# kid on the Aerospace tech support line to none I repeat none of the mounting bolts were the correct size or length, all the rotor mounting holes had to be retapped, the wheel studs are about three inches too long,( looks like Ben Heir chariot) and the final straw on the first check out pass the "Chinese" outer wheel bearings created such a wobble due to poor tolerance I almost wrecked.
JEG's was great about allowing a refund or swap for Wildwood etc but by this time I had so much time and $$ invested in fixing or replacing all the flaws and was close to the Belle Rose event I choose to leave alone, I.e. new American bearings, machine work, and correct bolts etc.
On the lighter side after over a week of coming in at night from the garage upset my wife thought the brake companies name was "Damn" :-)
Jim Parsons is offline   Reply With Quote
Old 05-18-2011, 10:47 AM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
I also used the Aerospace brakes on my Camaro. The brakes fit well and the install was very easy. There were a few holes that I had to chase with a tap. Once the brakes were installed they worked flawlessly and the braking is miles ahead of the drum brakes. You do have to be somewhat mechanically inclined to do the job and be able to follow directions. I bought my brake kits through ART in St Petersburg Fl. Aerospace is also located in St Petersburg. I thought the quality was in line with the cost.
Mike Pearson 2485 SS
Old 05-18-2011, 01:20 PM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Street car or race car? For a street car, I recommend the Stainless products over true race car stuff - much more durable.
Dwight Southerland is online now   Reply With Quote
Old 05-24-2011, 09:42 PM   #8
THE LEGEND
Greg,
We used Aerospace on "OUR" Nova worked good.
I also put a set on my Camaro. Very easy installation and almost a year and 400 runs later still stopping.
Chip
THE LEGEND is offline   Reply With Quote
Old 05-25-2011, 02:27 AM   #9
greg fulk
greg fulk's Avatar
Wink Re: Front brakes 67 Camaro?
Thanks guys! The car is a 12. second Street/Strip car it has manual drums all the way around now & dose not stop well!
Old 05-25-2011, 09:54 PM   #10
Tim B
Tim B's Avatar
I put wilwood disc brake's on the front of my 67 camaro, easiest swap I ever did. Stopped great going 9.50s
Tim Blount S/C Q/R 310T
Tim B is offline   Reply With Quote
