#11 |
Liked 14 Times in 2 Posts
I just want to race a real "stock" car and can't. IHRA used to have their Pure Stock divisions in the 1970s and 1980s. Are they still around?
#12 |
Yes, But the car has to be in the classification guide...
Danny Waters, Sr / 73 Duster "340" |
#13 |
its in NHRA's, would that be enough for a cross over?
Chad Rhodes 2113 I/SA |
#14 |
Banned
Liked 235 Times in 110 Posts
Bobby....Danny Waters Sr.should be able to tell you if it would be legal and in the guide. IHRA uses the NHRA guide sometimes. It would be a B/PS which is the same 9 lb wt. break as C/SA or C/S stick. The sticks and automatics run heads up in pure stock. The index was 12.45 the last time I looked in drag review. At least put a 9 " slick or some DOT drag slicks on it and open the exhaust (cut outs) to have a half decent chance to run the index number. Very few B/PS cars running (if any) so if you could run 12.44/12.45 it woud just be a shoe polish race for the eliminator just like NHRA stock is 99% of the time.
P.S. The best part of pure stock is you do NOT need to install a roll bar and safety harness in your brand new street ride. Factory OEM seat belts or aftermarket lap belts and a helmet is all that is required to go thru tech for pure stock unless your car runs quicker than 11.50. If you ran an NHRA or IHRA regular stock class like M/S (14 lb. break) and above then the roll bar and harness are required. Last edited by X-TECH MAN; 04-06-2011 at 08:45 PM. |
#15 |
Bobby , I will try to check the class books this weekend at Maryland and see if it is in the book.
I will let you know....
