Old 04-04-2011, 10:10 AM   #26
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: Help!!
Ed, I'll assume from the business you're in you have a DVOM? Hook it to the power supply circuit for your MSD or FAST unit, most have a record function to record high, low and average voltage set it to 1ms record speed and make a lap. If all looks well there, hook up to your crk. sensor circuit, also record set to AC voltage and monitor, a sudden change here would indicate an issue. Hoe are your Ign. components powered/ Relay, direct from switch? I have seen relays cut on and off due to points bounce, What sample rate does you datalogger have? Sorry for all the questions, just intrigued by the problem. Joe
Joe Buchanan SS/BX 3117
