Old 11-11-2010, 02:39 PM   #6
Jeff Lee
Jeff Lee's Avatar
Default Re: deck height:
Then I would definitely get confirmation on it.
The "old way" meant if the specs were zero deck then it was zero deck. But as you say, that may not matter. But make sure you have the right rocker ratio when obtaining the spec'ed cam lift measured at the valve!
Jeff Lee 7494 D/S '70 AMX
