Old 10-14-2010, 01:45 PM   #4
treessavoy
Liked 4 Times in 4 Posts
Default Re: Front Suspension Rebuild Questions
I have a '64 Savoy with a basically stock suspension in the front. I use the 6cyl torsion bars (mine were used bars, a little less stiff). Use a stock rebuild kit with stock type rubber parts in the rebuild and delete the sway bar, front shocks are important (talk to a dealer for his recommendations) and change over to disc brakes.
Alan's right, you cannot modify the A arm's but you can remove the bumper to allow more lift.
There's lots of guys in here that can help you with serious front end tricks.
Front end alignment is critical and Mopar has a performance manual that covers the way it should be done or ask one of the Mopar racers for particulars.
Good luck,
JimR
Jim Rountree
