Old 05-29-2007, 08:15 PM   #20
Painter
Guest
Posts: n/a
Default
For anyone blessed with Goodyear Marithon trailer tires I found a factory bulliten that we all should be aware of. It states that if we are going to drive over 65 mph that the tires should be inflated 10 pounds more than the sidewall says. I got this bullitin after blowing two tires each on two back to back trips. I was able to not completely distroy 3 of the 4 tires by catching them very hot at fuel and rest stops. They had what looked like blowouts on the innner sidewall. When we took them off of the rim the inside of the tire was perfect. The number of the bullitin is 2006-06.
Painter
