Record holding dodge 318
Complete engine as run, currently holds the GT/HA and GT/IA NHRA national records. Mopar R block with 4-bolt mains, bushed lifter bores, Crankshaft Specialist crank 2.100 crank pin, Manley rods, JE pistons, 576 cylinder heads by Modern Cylinder Head, with matching intake manifold with spacers and thermoquad. Jesel belt drive and rockers, Comp Cam, Crane Ultra Pro lifters, ATI dampner, MSD cranktrigger, Sheetmetal valve covers, alum. dist w/ Moroso plug wires, CSR water pump, ARP headstuds, this engine is complete carb to oil pan and is being sold with the matching converter. $16000.00
Denny Steward
(717) 676-3349
