Old 09-12-2010, 08:41 PM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Doug Nash 4+1 Help
check the detent in the trans its a steel ball with a spring,you mite have a bind from 2-3 and also the case holes for the shift forks ,as those transmission get older the holes start to elongate and that affects the detents ,,i used to run one and the holes where an issue,should have re bushed the case but sold the trans ,,pull the trans out and mount the shifter on the trans a try to duplicate the the shift but you will need an assitant to turn the input shaft ,you mite find something there gmonde
