Liked 460 Times in 91 Posts
I leave at 4000 on mine and have the best R/T at that..........
Bob Bender 144 O/SA 2010-2012 National Record Holder |
1100 # of brake pressure, 3400 in the stutter box, gas pedal on the floor, will go.020 to red. short time is 1.48 to 1.55 with a old old 4500 rpm 8" A-1 torque converter and a 2.78 low gear C-4, 5.14 gear and 29X9 Hoosier's car weighs 3520 with me in it.
67 Ford Fairlane F/SA 749 |
Stall speed will change your R/Ts but every car is different, my bracket car changes about .010 for every 200 rpm change. There are some different ways to change your R/Ts if the stall speed dont work for you or your car. You can adjust front and rear tire pressures or adjust the travel in your front end, if you tighten your front up it will make your R/Ts quicker but you will be more likely to have traction problems. Its all in finding what works for you and your car.
