Old 08-17-2010, 06:28 AM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: 2 Unrelated questions but need some help
Go to building supply store and look for silver colored silicon in a caulking tube that says it is for sealing aluminum windows. Be sure the area you want to seal is very clean - use laquer thinner, brake parts cleaner, etc.; the surfaces should be sqeaky clean. Apply the silicon sparingly and forced into the gap between the wheel halves. Too much silicon will add to the mass of the material and can be forced out by the inertial forces of the wheel spinning at high rpm.
That's the procedure I have always found to work.
