Old 06-27-2010, 11:51 PM   #5
hemidup
Default Re: What type of fluid does NHRA use
Thanks all. I use an old glass Pyrex burette. I've since sent the heads to 2 other reputable shops and we all came up with the same senario. My supplied factory heads are illegal. Now, I just have to make them work. Rocker arms are next. I bought an additional 40 intake and 40 exhaust rocker arms for the mix and match and hopefully find the correct stock rocker's for the correct stock ratio with a custom ground camshaft and you all know how long that could take... lobe by lobe
Jerry Williams
NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's.
hemidup is offline   Reply With Quote
