#11 | |
Thanks Jeff for your words, I think the 03 mach-1 would be fun, I did the calculation and as far as I know will fit on E/S. Edgar |
#12 |
Liked 24 Times in 13 Posts
I agree with Dave Casey's findings and I will be the first to admit I know nothing about the Ford engines power band, or how it effects performance when switching from the 4 speed to the 5 speed, but I do know about the LT1 Chevrolets' abilities in these very same areas.
Probably few remember but Merc and I ran a 94 Camaro LT1 powered car in 1999 and 2000 which Woodro did the engines for and was the D/S NHRA National Record Holder @ 10.52 which was pretty quick in it's day. For what it is worth this car never ran as quick with the 5 speed as it did the 4 speed. On the best days it was a wash and most of the time the 4 speed was a couple hundreths quicker, so unless there has been some startling new developments in this area lately (like a higher/wider rpm power band) I think the data we achieved in this application is fairly factual. In fact I still have a like new G Force 5 speed available with a 3:16 low and a 3:25 low gear set complete with a Long Shifter and the correct driveshaft for a late model Camaro if anyone out there is interested. MK
Mike Keener A/S B/S C/SM |
#13 | |
Edgar |
#14 |
The bottom line on most of this stuff is you never really know! So if you want to go fast, you have to try, try, and try again! And yup, that sure can get expensive!
And since you are looking at racing a basically unchartered path with this combo, you will have considerable time and effort involved into making this a successful venture. That unfortunately sometimes, takes a fat wallet! Look at Mike Keener here, two transmissions taking up space. I think I'll PM Mike and see if I can steal one from him... ![]()
Jeff Lee 7494 D/S '70 AMX |
#15 |
Liked 308 Times in 103 Posts
I was wondering on these 4 -5 speed comparisions about first gear ratios could ones that ran better w 4 speed had lower first in the 5 speed and not enough rpm to get enough wheel speed with lower first gear and that hurt there performance?
Mike Taylor 3601 |
#16 |
Liked 22 Times in 22 Posts
I am just now getting ready to use 5 gears for the first time. will let everyone no. but if 4 gears were faster, prostock would be using them. Just my 2 cents.
don,t have one |
#17 |
Liked 70 Times in 29 Posts
I think your advantage would come from having less drop between the gears.
First may not be all that much lower in a 5 speed, but the drop isn't as great to the next gear. I'll bet that most people's fifth gear is still 1:1.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
#18 |
All high gear drag cars in class are 1 to 1.
don,t have one |
#19 |
I think it is true that the engine's specific power band plays a part in the question of what improvement is seen with a 5 speed. However, I am pretty sure a 5 speed will need to be shifted differently than a 4 speed.
Here's what I'm thinking... We grossly over rev our Super Stock engines on the gear change. 4 speed guys are revving them about 700-1000 over peak HP, maybe more. My limited understanding is comp guys with 5 gears are running about 300 over peak HP before shifting. Please chime in if you disagree with my #'s. I am not an expert with comp engines. My belief is the more gears you have, the less you will need to run past peak horsepower to recover on the subsequent gear. Also, I wonder if the finish line over rev could/should be reduced with a 5 speed. Again, my limited understanding is that comp guys are running about 400-500 over peak HP instead of us Super Stock guys running 1300-2000 over. Just some thoughts... Last edited by Mike Dahl; 05-21-2010 at 01:23 PM. |
#20 |
Any manual transmission, either 4-speed or 5-speed, needs proper gear ratio selection for optimum performance based on the power band of the engine. Engines with narrow power bands, benefit with 5-speeds.
The gear ratio selection needs to be optimized to allow the engine to recover and stay in its power band through all gears. In order to keep their engines in the power band, I have known of SS racers with small CID engines, that must run a 4-speed, put a 1.1 or 1.2 high gear on their 4-speeds. |
