Old 05-09-2010, 12:00 PM   #39
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default Re: what combo is better ?
A few years ago I ran a 396/325 HP Stick Shift combo in I/S with a 68 Impala If the car is built right it won't break parts like everybody thinks. I had over 100 passes on that car with only one set of gears broken, and that was because they were not Pro Gears I also ran a lightweight flywheel with the Jerico. Car went quick as 11.71 at 4095 pounds in I/S It is on YouTube
I am now using that same motor and building a 84 Olds Cutlass to run in a IHRA Stock GT class with the stick. (SGT/B or C)
Will Lamprecht
