Excessive positive caster will cause a high speed shimmy. Suspension is going into jounce upon decel thus moving the lower ball joint up and the upper ball joint up and back increasing positive caster.
A decrease in the positive caster setting, or a steering dampner should resolve the issue. A stiffer shock setting that prevents nose dive may help also, but I recommend a caster setting change. |
Liked 15 Times in 7 Posts
Thanks for the info Gary will check it out,........bryan
Liked 2,485 Times in 697 Posts
Last time I had that problem on my Demon.......lower control arm bushings were really egg shaped from coming down hard on front wheels. You may be able to see them (arms) rubbing on K .member. Jack it up and check for looseness. While you are under there look at strut rod bushings too. Both common problems on Mopars. Call me if you need to know more.
PS got all your stuff gathered up John Irving |
How ya been? Going testing sunday with 72 340 a body, will drive this till mine is done.. found our wobble was bad drag link,
Liked 880 Times in 311 Posts
You might also check all the connection points on the drag link for wear or being loose...
Adger Smith (Former SS) |
thanks that was our problem got it fixed today thanks again bdixon
