#11 |
Liked 5 Times in 3 Posts
Drooze get ya a sponge type air cleaner freeze it with NOS....install it before the water box...as it melts going down track ..... be completely gone by the time you get to the scales
#12 | |
#13 |
Liked 244 Times in 26 Posts
Sounds like an egr system or PVC.
#14 |
Liked 6 Times in 3 Posts
you should be able to save a ton on the next set of custom headers, cause unless the next set are "zoomies" i gotta figure you'll be out to lunch on your scavaging?
Unless you use a F-1 intake valve stlye solinoid operated control valve which will only allow flow at high pressure hooked up to a pretty fancy custom program on you msd digital box! And even then, if you don't plan on running zoomies, will your "super secret material" have enough pressure to force itself into the exhaust port rather than being sucked out by the next cylinder's exhaust pull? This is a great IDEA! run with it man. I don't race NHRA so i say you go! i am just thinking.... i want to see the you-tube video of you blowing the headers right off the motor because of some secondary combustion that happened about 1/2" down the tube and the delay from charge to compression happen at the same time the valve was closed. Just think, you need to design this system to activate once every .01 seconds if your engine pulls 7500 rpm. Makes you wonder what the first off peice from MSD cost? Keep us posted, photos and video, lots of videos! Ian |
#15 |
Liked 11 Times in 8 Posts
Soooo..... are you wanting someones blessing to cheat? Just because the rulebook doesn't specifically state you can't do it doesn't mean you can, I found that out the hard way. Ever since when ever I had some sort of "out of the box" idea I'd run it by an Official first, saves alot of head aches. I'd try to make the motor last a race or two before I'd be trying to reinvent the wheel. But cudos on your imagination. Joe
Joe Buchanan SS/BX 3117 |
#16 |
Liked 544 Times in 213 Posts
I love this one Tom and agree 1000%
"Super Secret Nuclear Squirrel Crack"
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 03-08-2010 at 02:40 PM. |
#17 | |
But I'm sure all the supporters will attack this line of thinking as being to critical....
#18 |
Drooze wasn't asking for someone to bless cheating....
Cheating is doing something that is against the rules. If the rules don't say you can't do it, then you can. He was trying to be sure that he hadn't missed something in the rules. It takes courage to ask questions here, since so many seem to just want to bust chops. But Drooze doesn't care, and since his inbox is always full of messages from good people who say Ignore the nasties....He will continue to post, and let the attackers do the only thing they can do,,, attack. As for waiting to ask this question, this was posted a long time before the second engine separated, so reading the post dates and knowing the time lines of circumstances would make your comments more meaningful, and keep them from appearing as just cheap shots. Have we now broken two 6.1 Hemi Drag Pak engines? Yes, we have! And we may break another one, or two before we are done. We are pushing forward on a number of areas with these engines, and we are finding out what works, and what doesn't.. But whose business is it if we toast 2, or 10 engines? At the end of the day, we will have a car that runs as welll as we are trying to make it run. You can count on that, because we don't intend to sit back and criticize what others are doing, we are moving forward, and traveling the road less traveled.. So you do what you do, and we will do what do. Have a nice day. David The New Hemi Guy ________ R65 Last edited by NewHemi; 04-05-2011 at 10:10 PM. |
#19 | |
Not in the least, I am going to build a proof of concept on another engine, that has been planned for a long time, Im working with a material that has properties you arent really used to seeing in a solid before it transitions. Now that being said, I am doing it period I am going to try it, the percentage of a significant sucess is I estimate 2-3 percent. That all , but the only way to see if the result is desirable is to try it. This ideas application has several side effect one lowering exhaust valve temperatures but possibly 3-400 degrees, as well as increasing combustion pressure by perhaps up from 7-10% a significant amount in my book. The QUESTION on it being specifically ILLEGAL, was an afterthought, a "Holy cow nothing in the rules disallows this" It wasnt meant for application on a drag engine , originally. But a say 5% power increase in my book IF it were succesful (a 2-3% chance it would be) then well the possiblity for use in a Drag engine becomes obvious. I am not going to bother an NHRA official with it UNLESS it works, then Ill ask, I wont be suprised at the answer if its NO, but there has to be a REASON for the answer, if I was going to put it in the intake air chage that is specifically NOT allowed, hence there would be a reason, but, well....I asked if Titanium valve springs were allowed in Stock and the answer was "If It dosent specifically make mention of the material, and in the case of springs no materials are mentioned so YES you can use Titanium springs" That from Bruce Bachelder. So, to me that would follow the same logic for this pattern. So far, some have given reasonable opinions as to why they think it would get axed, those I appreciate, I see the reasoning, and they are food for thought, as was the WHOLE purpose of the thread, "Thinking out loud" as it were. That being said, not a single person has pointed me to a rule in the book that would disallow it, NOW In abscence of a rule that is in black and white, it raises this to be something that IF successful is WORTH asking, it looks pretty stupid to ASK Something that it says NO to explicitly, it is NOT stupid to ask on something that is not disallowed, whats the worst that could happen ? The answer would be no. If I were going to cheat which is something I cannot and will not do, I find it useless, anyone can cheat and win, anyone. To do it above board is the challenge. If I were the type of person to cheat do you think I would ask it here for all to see ? I mean really.... Is it a longshot, hell yes, like all longshots the payoffs are big if it were to be successful. If......my ether injection idea woulda worked too before my dad kiboshed that one on my minibike....sounded like a good idea when I was 9, in retrospect having a can with a solenoid under my legs fogging ether into a 10 hp Techumsa on a Rupp frame wasnt a great idea, but in all fairness he did let me put the 10hp motor on the minibike ![]()
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) Last edited by Chris "drooze" Wertman; 03-08-2010 at 09:15 PM. |
#20 |
