Ron,
Sounds like you just need a couple wheel chocks or saddles for the front wheels to sit in so they dont move around. I say that becuase you are using the car lift to hold the front of the dragster up. If that is the case I have a set of hard rubber wheel saddles that I use when I not hanging my dragster. I cant tell you where I found them or got them nor cant find them anywhere on the internet. But the name on them is: T C Christner and Sons 217 223 7993. You can just throw them on the lift and sit the tires in them and the dragster should be ok. When I hang my car the front wheels sit in aluminum saddles made by Motorsports. All either one of these do is just keep the dragster from walking around . If you tie the front end down you probably dont need either. Call me if you need more info. Kent |
