#28 |
Liked 317 Times in 108 Posts
Slik tom,
Using what I have or can make or repair is my life story also. Driving stick is just like riding bicycle. Drooze, If you have 72 challenger I would'nt even put that trans in it sell it. Nobody uses those trans because you can buy a good trans probaly for what you would spend on that one. Overdrive gears aren't counted for number of gears of trans if I'm correct Idon't know if there are any 5spd stockers? More gears you have the better you can make the ratios faster the car goes on SS/AH 5 spd would help because less drop on shifts would calm down car and clutch could probaly be softer because ratios closer together can soften clutch more before you run through it. Mike Taylor 3601 |
