Old 02-25-2010, 11:34 PM   #19
Scotty D
Default Re: Manual Trans Help
hey drooze keep up the good work on pop's car can't wait to see it run and see the numbers.on the other question in stock if i'm not mistaken you can use the same amount of forward speeds that the car came with from the factory,that being said why go to a 4speed when you could use a 5 or 6 speed and go to a deeper low gear set with not as much rpm drop on the gear changes to keep the motor in its powerband easier and make it more efficient.
Scotty D is offline   Reply With Quote
