Liked 4 Times in 1 Post
Hey, guys. My project is a 1976 Firebird with a 400. I am building it for NHRA Stock and i want to run a 4 speed. At this time, a Jericho is out of the question so what is my best bet? Super T10? Thanks for the help.
Spend the extra for a Jerico, it will pay for itself in the end
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Liked 165 Times in 59 Posts
if your going to run a stick you need to go with a good trans ,jerico,liberty,but depends how resourceful you are you mite be able to find a doug nash five speed that is converted to a four speed but finding gear ratios will be a challenge to find ,,strong but old
gmonde |
Liked 496 Times in 115 Posts
You car is only as strong as the weakest link. The T10 would be the weakest link.
68 Chevy11 327 F/S |
Liked 5,114 Times in 1,948 Posts
Your problem won't be so much the trans , but rather ,the clutch.
Too much weight, not enough hp and rpm to use counterweights effectively. I f you can't afford a Jericho, I'm going to assume you won't be able to put a good clutch in it either. You CAN find an old Doug Nash 4+1 with about a 2.96 low and it will be strong enough, but remember, a 1 to1 4th gear, is still driving through the cluster. You 'll have some loss there. Bottom line though, is, and trust me when I tell you this (been there, done that) , this whole deal is a bad idea. I would advise you to not do this.
Liked 2 Times in 2 Posts
What whole deal is a bad idea? Running a stick or building a stocker?
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#7 | |
#8 | |
Running a stick with that combination.
#9 | |
Yes, there are moderately priced B&B /Long style 10.5 -11 " that are somewhat adjustable, but I don't believe they will get the job done in this application. By that I mean you're most likely to either break parts or smoke the disc in the waterbox. Even if you find a happy medium , I don't think the 60' times will be consistent enough to win races. I'm not trying to discourage you from building a Stocker, by any means. We need all we can get, just not this combination.
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 02-25-2010 at 02:01 AM. |
#10 | |
Liked 8 Times in 7 Posts
yes, i'll be using a st-10 w/ 3.44 1st,bunch lighter car,though |
