Old 02-02-2010, 05:24 PM   #11
Irv Johns
Liked 2 Times in 2 Posts
Smile Re: Challenger Drag Pak Owners
If your going to go 8.99 you better do it first run, cause when you go 9.350 the horsepower fairy gives you 13 HP and then you have to carry another 97 lbs in AA/Sa or run 974 in A/sa and get the same gift only its 104 Lbs. So therfore the fastter you go the fatter the will make yor weight box.
Irv Johns is offline   Reply With Quote
