Liked 198 Times in 79 Posts
Has anyone out there used this product? Does it seal small water leaks as the product description claims?
Mike Fuller 396 STK 3961 SS |
Yes, it does. I usually follow it with sodium silicate, found at the local drug store.
Alan Roehrich 212A G/S |
Thanks Alan.
in the old days of cast iron headed modified production cars,they bought stock in ceramic seal and usually used it every time the raced.engine builders always said if it didn't leak a little it wasn't going to be fast.
Liked 1,937 Times in 582 Posts
Mike,
If you have a crack or hole in the head you wll not have very good luck with any type of block sealer. I have tried them all. Sometimes you can get a temp fix from it. In my experience I have always had to find the cause of the water leak and weld or epoxy the problem. good luck
Mike Pearson 2485 SS |
Liked 780 Times in 194 Posts
This is the best product I have found for pesky water leaks in heavily ported heads: http://www.steelseal.com Pricey, but works.
Liked 60 Times in 12 Posts
There is also a Goodson product we used on my brothers car a few yrs ago. It worked real well. Its a liquid, and I dont think he's had any more issues with it.
2894 STK |
Thanks for all the advice. First had expirence is the best way to resolve thiese kind of problems.
