Old 12-28-2009, 12:08 AM   #1
art leong
Default Re: 2 step on fuel injected cars
Originally Posted by drooze View Post
Art, curious what injectors ? The 687 cc ?
Nothing to do with the fuel in the oil, hell at 1.56 under Id agree with you, just curious how you were getting THAT much down the cylinders even
Was that on a turbo or NA setup ?
Cheers
Chris
The injectors are from a stock Pt Cruiser I don't even know what the specs are.
I'm N/A no speed screw here. We might have been able to take fuel out of the program under a certain rpm even with wide open throttle. But before I got the 2 step I'd just hold the button and mat it, the transbrake would hold the motor to 4500.
With the 2 step I'd make a run and push oil out all over the place. Clean it up and run for 10 runs without the 2 step. Clean and no problems. Try the 2 step one more time, push oil all over and break tip off a spark plug.
Art Leong 2095 SS
