Exactly
Art Leong 2095 SS |
Liked 223 Times in 73 Posts
Art what kind of car and ecu if that is not to much to ask you dont have to answer if you dont want to that is understandable
I use an MSD 2 step on mine with the FAST XFI ECU, no problems. It has nothing to do with the injectors, the MSD kills the spark. I had one customer having problems with that but he had his MSD grounded to the battery along with his XFI ECU. Don't do that, ground the MSD to the engine. Not the floor pan, roll cage, battery, etc. Directly to the engine. If your pushing fuel past the rings you much be over-fueling it. Don't do your launch air/fuel tuning from your wideband, if you can't do it on an engine dyno without the 2 step (I've never had mine on an engine dyno), go by your 60' times. The miss-firing while on the 2 step will make it look very lean to your wideband, you can end up leaving very rich. My wideband doesn't read correctly until nearly 6000 RPM on the launch. Just another reason they typically run quicker in open loop. It would be trying to fatten up a false lean condition. If your trying to run it in closed loop, be sure to set your minimum closed loop enable RPM well above your launch RPM. I picked up over a tenth just by putting mine back into full time open loop.
Ed Wright 4156 SS/JA |
My ECU is a ViPec. I use LS1 coils so the only standalone 2 step I could get was from Lingenfelter The 2 step held the rpm it was set for. But the motor was over fueling.
I run open loop all the time. I don't run a long collector so the wideband is not to accurate at lower rpms. The car has been setup on a chassis dyno using the quick tune setup in the ECU I used a fast ECU and msd dis2. and you didn't have to worry about what to dial in. You had to worry about whether the car would start. The ViPec is a pleasure to use it starts the car with ease even in cold weather, idles great at low rpms and I don't even have the idle speed control hooked up.
Art Leong 2095 SS |
You simply had something wrong. Never a problem with my FAST, or the other racers I help that uses them. You said before you had an older version they no longer sell or support. The guys I work with that use that older version also have no problems. You had something wrong you could not fix, that does not make FAST products bad. If your pushing fuel past your rings when on the 2 step, you still have, or are doing, something wrong.
#6 | |
I guess I'm going to have to fix that terrible problem.
Art Leong 2095 SS |
#7 | |
Art, curious what injectors ? The 687 cc ?
Nothing to do with the fuel in the oil, hell at 1.56 under Id agree with you, just curious how you were getting THAT much down the cylinders even ![]() Was that on a turbo or NA setup ? Cheers Chris Quote:
#8 | |
That is a lot fo fuel. I wonder if the Lingenfelter 2 step is screwing with your ECU? If your battery is not grounded to the engine you might run a ground cable all the way to the engine. The biggest source of problems with EFI is grounds. Heck, you may be as far under as the Caddy in Stock when you get it fixed. 4500 isn't very high, how big is your engine?
Ed Wright 4156 SS/JA Last edited by Ed Wright; 12-28-2009 at 10:43 AM. |
Liked 27 Times in 14 Posts
Before I had the Accel management system I had a 2 step setup in the car with no issues. I have it off the brakelight switch and a toggle switch to shut it off so you cant reactivate it when you tap the brake pedal.
