Old 12-26-2009, 05:43 PM   #1
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
Default Re: Super Class rule clarification
No Freddie....you can't hit the chip on the high end....intentionally.....(it does work though)....but you would be turned in in Div 3...and I bet my Div 2 buddies wouldn't be happy either....
on the Fi question.....cutting the fuel is fine as long as you close the throttle some amount....with a linkage stop or something similar....just cutting the fuel would be suspect and sooner or later someone wouldn't like it....I'm not making the rules...only giving you my opinion....nothing else...
Rock
CBS is offline   Reply With Quote
Old 12-26-2009, 06:17 PM   #2
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Rock
Not intentional.. but I need the gear to get the car to leave and run the #'s, but for some reason the car hits the chip at around 1100'. I can prob. put a 500rpm higher chip in it and not hurt anything, but I dont like to run my FORD much over 7500 as it is...
I dont know how much of a issue it will be because I have never run it with a stop on it, and the car will definaly need to be slowed down.... I have been 9.2's so far, and thats with hitting the chip.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 12-26-2009, 06:54 PM   #3
danny waters sr
danny waters sr's Avatar
Lightbulb Re: Super Class rule clarification
Leave at lower rpm and short shift and or add weight.
Old 12-28-2009, 09:36 AM   #4
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Freddie, what size engine and what gear do you run? I like you, run Ford engines in both my cars and without knowing what gear you are running find it hard to believe that by changing it you would have a problem cutting a light. In my ranger I ran a 4.29 gear and could go red anywhere, even on those .370 tree's. My thunderbird I run a 4.10 gear now, but had a 4.29 gear in it before and saw no difference at the tree. With that car I have had as many as 40 numbers in the box even with the 4.10 gear. A Ford engine makes more torque than a chevy so it can be geared different. Also it will make it's power at a lower rpm so if the truth is known you will run faster by regearing your car as well.
Chuck
C and W Racing is offline   Reply With Quote
Old 12-28-2009, 09:50 AM   #5
Freddie
Freddie's Avatar
When I set the car up it was set up in NMRA H/S trim with a 363 small block that will easily take 8500+. car has a 4.30 gear in it now, and a little smaller 363, I could not justify spending the $$$ to try NMRA anymore as they have gotten WAY out of hand.
New motor I would like to keep around 7500 so it will last longer. Car is still running the 28x10.5's and sitting at 2650 race wieght. I changed converters this year also, I can go red on a .370 tree with no issues, car has been 9.teens, and usually runs through the traps at 8800. For local bracket racing I put a 7000 chip in it since almost everything brackets now is on the 1/8 it didnt matter... I was thinking about putting the 3.73's back in it, and just let it kill off the first 100' or so... then see how much more I need to slow it down to run S/G..
