Old 11-10-2009, 01:24 PM   #1
novassdude
Liked 136 Times in 49 Posts
Default best head for 1972 chevy
What is the best head to use on the 1972 200hp 350 chevy? This is for a stocker application.
novassdude is offline   Reply With Quote
Old 11-10-2009, 02:33 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: best head for 1972 chevy
993,487,881,882 appear to be the heads listed in the NHRA guide
CC vol listed in NHRA Super Stock Cyl. vol. list
---993 161 65
---487 161 65
---881 160 60
---882 160 60
I would say 993 or 487
check out the optional cam and piston choices listed :
* = Optional cam lift 401/410
Note A = J.E. #161757 piston uses an .080” dish, TRW #L2403N piston uses a .065 depth and CP #C14-CP piston has a depth of .092. All volumes OK.
You did want to know what NHRA legal head fit the 200 hp 350 engine?
Adger Smith (Former SS)
Old 11-10-2009, 02:49 PM   #3
novassdude
Yes Adger That is what I am looking for. I was woundering if any one has a tendency to out flow the others. I did know about the optional cam that is part of the reason for looking at this one.
Old 11-10-2009, 06:06 PM   #4
Dave Ley
Liked 241 Times in 44 Posts
Send a message via AIM to Dave Ley
The 487X is the best choice.
Dave Ley
Dave Ley is online now   Reply With Quote
Old 11-10-2009, 07:03 PM   #5
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
I'll 2nd that. Have very good luck out of the 487 over the years.
Old 11-11-2009, 11:59 AM   #6
Chris Hardy
Guest
Posts: n/a
From working and flow testing all of them back to back. All of the casting can flow exactly the same when the same work, valves and valve jobs are used. The smaller exhaust ports make more power. The 487X works better with larger cubic inch motors (350 and above). I hope this helps.
Best Regards,
Chris Hardy
chrishardy@racingenginetechnologies.com
231-773-7252
