Liked 319 Times in 108 Posts
James,
Did you see former governor Rob on Letterman? Told Letterman he always wanted to be on his show in the worst way. Dave replied Well your'e on it in the worst way!!! With clutchless IF YOU HOLD in gear at slow speeds like going to water box as example when you slow down trans will ratchet on sliders and stay in gear this is barely above idle in low gear, but going down track racing if you lift or blow tires off bad will come out of gear and if you try to put back in goes to high and will wipeout slider and face plate on high gear,when in high gear you can lift off/on gas but have to hold trans in gear. I don't know about any other stick guys but my hand never leaves the shifter anyway. I'll give up stick cars when they pry my cold dead fingers off the shifter. Mike Taylor 3601 |
Mike Taylor 3601 now thats a diehard stick racer...
Bub Whitaker |
Liked 26 Times in 13 Posts
On another thread Mike Crutchfield, who is a member of the SRAC (remember them?) said that the committee had voted on the clutchless in SS and it was voted down. For those who forgot, the SRAC is supposed to be the sportsman racers representative group to the NHRA guys that actually make the rules. If the clutchless is permitted, it is just another example of the ineffectiveness of the SRAC, the same problem that caused several of the original members of the committee to quit after less than a year since their input was being ignored.
The question posed about where this rule change was coming from is the real issue. This happens time and time again. Who benefits? Who is pushing for the change when the racers representative body has voted it down? Note that Danny Gracia is mentioned over and over again as the source of the information that the rule will change. Also note that he is not on any of the rules making committees as listed on the NHRA website. So is the situation one where if someone with clout can convince Mr Gracia, it becomes a "done deal'?
Bill Harris ex 2172 STK ex 2272 S/S |
I'll give up stick cars when they pry my cold dead fingers off the shifter. Mike Taylor 3601[/QUOTE] I second that! ![]() |
#6 | |
On a side note, I suppose if money is no object and you can use a clutchless trans then you might as well hook an air shifter to it? I mean, autos in SS have an air shifter for their ONE shift. So, I suppose air/electric shifters will be legal also? ____________________ Andy Stone 1102 A/S 1112 SS/C |
as i mentioned in my intro post me and a friend are teaming up to build a 283 4 speed nova we are both new to super stock ive been racing et handicap pro for a few years got boring, so were looking to have some real fun i was pretty pumped until i read this thread if clutchless is allowed we wont be able to afford it.and we'd have to use an automatic and that would just plain blow. so keep the clutch assisted transmissions!!! even though i have never raced in s or ss i say clutchless is for comp and prostock!
Liked 477 Times in 43 Posts
Are there any real stick cars in SS that really use the clutch. I mean all you Jerico guys dont use it.
#9 | |
Sean Fischer ![]() |
#10 | |
I Only Used My Clutch Off The Line On The Old CRASH Boxs Back In The Day Also!...Thats The Whole Reason To MODIFY The Gears.. Put This Into Perspective As Well....You Are Allowed To Have: A Mopar,Chevrolet,Pontiac Etc.. Engine And Ford Rear-End...This Never Came In These Cars Either..WTF.. SS |
