Old 10-22-2009, 01:15 PM   #1
80 monte
80 monte's Avatar
Default 305 head gaskets
What head gaskets would you sugest for a 0.030" over 305, I dont want to run the stock 0.041" thick gaskets I want to be around 0.026- 0.020" thick compressed. The only ones I can find are from GM performance, just wondering if anyone else has a line or a lead on some different brands I could look into.
Thank you before hand. Cam
It's only a 305
305 0.030" over, 12:1 comp, 461 casting heads, 1.90" in & 1.50" ex, Comp Cams XE284H,
[SIGPIC][/SIGPIC]
80 monte is offline   Reply With Quote
Old 10-22-2009, 01:35 PM   #2
Greg Turk
Greg Turk's Avatar
Liked 19 Times in 4 Posts
Default Re: 305 head gaskets
Try Cometic... a bit more money but available in any specified thickness..., they are also reusable, a bonus considering the price!!!!
good luck fellow Canuck!!!
later
TURKMAN
4002 Stock, 4002 Super Stock
Greg Turk is offline   Reply With Quote
Old 10-22-2009, 02:04 PM   #3
80 monte
80 monte's Avatar
later
Thank you I will try them any key words or a link I can try to make it a little quicker
It's only a 305
[SIGPIC][/SIGPIC]
Old 10-22-2009, 02:29 PM   #4
Greg Turk
Greg Turk's Avatar
Ah, cometic.com
toll free 1-800- 752-9850
440-354-0777
they are out of OHIO
TURKMAN
Old 10-22-2009, 02:31 PM   #5
80 monte
80 monte's Avatar
thanks again
It's only a 305
[SIGPIC][/SIGPIC]
Old 10-23-2009, 02:11 PM   #6
80 monte
80 monte's Avatar
Anyone else have a source other than GM perf as cometic does not carry anything under a 4.100" bore gasket. The 305's require somewhere in the 3.800" range bore on the gasket, if I go too big I am going to loose comp. and sealing capabilities and maybe the chance of heat soaking the spark plug cooling jackets.
It's only a 305
[SIGPIC][/SIGPIC]
Old 10-23-2009, 08:25 PM   #7
Bob Gullett
Bob Gullett's Avatar
Liked 464 Times in 113 Posts
We have ordered the 305 Cometic gaskets several times with the small bore.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 10-23-2009, 08:46 PM   #8
james schaechter
Liked 1,428 Times in 296 Posts
Yes, Cometic makes all sizes. Most don't stock the small b ore stuff, but they make any size. We have 283 stuff made. Here are the thicknesses. If you need a contact at Cometic, let me know. Jim
.027
.030
.036
.040
.045
.051
.056
.060
.066
.070
.075
.080
.084
.086
.089
.092
.095
.098
.120
.140
James Schaechter 3163 STK
Old 10-23-2009, 10:26 PM   #9
Jamie Greening
Just ordered a pair 2 weeks ago for the camaro. It took about 5 day to get. You give them the bore and thickness and they custom make them. They were about 90 dollars a gasket but they reuseable. Call them they will take care of you.
Jamie Greening is offline   Reply With Quote
Old 10-24-2009, 03:31 AM   #10
J Halsey Jr
Corteco sells ones that are .028 thick crushed in there performance line for a 305.
J Halsey Jr is offline   Reply With Quote
