I forgot to state that mine is a 10 inch wheel with a 30.0 X 9.0 Hoosier radial - Lightweight. Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 419 Times in 85 Posts
You are going to have to do your homework. I had to do everything to get a 9 x 30 radail under the car. As John said narrow leaf springs and a lot of massaging. I wouls also start with a 8.5 inch rim if you have not done a lot of work to the car.
Liked 2,486 Times in 697 Posts
10" Rim with 4 and 7/8 or 5 back. 8.5 with 4.25 or 4.5 with small spacer if you must. Our Volare/Aspen combo has HUGE fenderwells by comparisions. Mopar makes a spring hanger that is .8" narrower that will bolt in A Body..... you might try that, it looks stock if you are good at rewelding spring hanger on housing but it probably is not legal but not very noticable.
Liked 6 Times in 5 Posts
Thanks for all the input guys.
I have to do work to the quarters on the car, and I'm OK with massaging the lips as I'm sure I'll need to. Planning on stretching the leading edge of the opening which will help with tire diameter, width is the major issue . John: are the hangars you are referring to the ones which move the spring inboard .80 inch? I have those now I just have to figure out how to "sneak" the rear shackles in .80 too. |
Liked 325 Times in 50 Posts
Make a housing the length you need, or you can get it made from Moser. Get exactly what you need, massage the wheel opening, and it will work. I personally like the 10 in rims better. Ours are 5" bs.
Jeff Teuton 4022 STK |
Todd is this the green Dart that you've had for eons?
In God I trust. |
That is right on hangers
