Old 09-22-2009, 02:23 AM   #1
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Default Re: 60' times
Rick, you should really start by comparing your on track incremental times and mph of the good runs to the bad. You can then make a better pinpoint of the spot where your losing your power. If your mph is up at 660 and 1320, then you can come to a conclusion, it's not the engine, trans or converter. Look at the other incrementals and find where it's dropping off and if it's only the 60' times that are slow. It may be as simple as the track your racing at may not be preparing the starting line properly due to the car counts being down. They could be trying to make up their profit margin there. I know a lot of the points races we ran at this year, we had to keep the car very loose to make up for a bad track.
Just another opinion. Hope it helps
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 09-25-2009, 09:59 AM   #2
Jack McCarthy
Liked 508 Times in 122 Posts
leak / comp test motor... maybe banged a few exhaust valves
jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 09-26-2009, 08:26 AM   #3
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
For my car it's the head gaskets leaking between cylinders when the 60 falls off, Paul.
Paul Precht is online now   Reply With Quote
Old 09-26-2009, 09:02 AM   #4
Chad Rhodes
converter
Chad Rhodes 2113 I/SA
Old 09-26-2009, 10:21 PM   #5
Liked 5,145 Times in 1,964 Posts
Originally Posted by Chad Rhodes View Post
converter
A torque converter that loses a tenth won't last long, and it'll let you know what the problem is.
Either the stall will go way down, or way up.
BTW, anybody attempting to check stall speed with the rear wheels on the ground ,will find themselves with a long vacation from NHRA. This is in response to the fatality at Fontana recently.
Old 09-27-2009, 08:40 AM   #6
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
i have to agree with marty ,,the track preperation has alot to to do with consistancy of 60' times ,,i know if you go on a saturday test and tune track will not be as good as a sunday points day race also,the time of day will affect track performance 12:00-2:30 with sun beating on the track will make for a greasy track
gmonde
Old 09-27-2009, 08:43 AM   #7
Chad Rhodes
very true, however a broken converter can do all sorts of strange stuff. as for cheching the stall, thats what a data logger, and testing are for
